안녕하세요.
포럼 질문이 모두 공개질의고 비공개가 안되는것 같아 질의에 제한이 있네요.
아래 로그의 일부와 상황에 대한 캡쳐를 보내드립니다.
(일부를 가립니다)
위와같이 드라이브를 제대로 읽어오지 못하면서
지속적으로 문제가 발생하며 원격 webdav 상태에서만 발생하는 문제입니다.
동상황 발생시 로컬 smb에서 문제 없음을 확인하였습니다.
(유료버전입니다)
아래 로그입니다.
2023-06-26 11:17:00.179 [ERROR] RD : WebDAV/None(ceoonly) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:17:00.386 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:17:24.213 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:17:24.299 [ERROR] RD : WebDAV/None(ceoonly) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:17:31.266 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:17:40.179 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:17:51.183 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:18:08.250 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:18:32.424 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:18:41.420 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:18:51.253 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:18:51.262 [ERROR] RD : WebDAV/None(mir_upload) : #### FOLDER ENUM : API Call Error : {“WinErrorCode”:5,“NotifyErrorCode”:104,“RaiException”:“WebDAV List : / : Failed : “,“Filename”:”/”,“WebExceptionStatus”:“ProtocolError”,“InnerException”:“401 Unauthorized”,“WebResponseCode”:401,“HttpException”:“Unauthorized : \n\n401 Unauthorized\n\n
Unauthorized
\nThis server could not verify that you\nare authorized to access the document\nrequested. Either you supplied the wrong\ncredentials (e.g., bad password), or your\nbrowser doesn’t understand how to supply\nthe credentials required.
\n\n”,“HttpReferenceMessage”:“\n\n401 Unauthorized\n\nUnauthorized
\n\n”}2023-06-26 11:19:02.326 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:19:18.427 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:19:43.327 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:19:46.841 [WARN] BGENUM : WebDAV(Work) : BACKGROUND ENUM INFO : QUEUE COUNT : 100
2023-06-26 11:19:46.841 [WARN] BGENUM : WebDAV(Work) : BACKGROUND ENUM INFO : PROCESS : \Device\HarddiskVolume4\Windows\explorer.exe : COUNT: 99
2023-06-26 11:19:46.841 [WARN] BGENUM : WebDAV(Work) : BACKGROUND ENUM INFO : PROCESS : \Device\HarddiskVolume4\Program Files\Honeyview\Honeyview.exe : COUNT: 1
2023-06-26 11:19:53.357 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:20:01.419 [INFO] BGENUM : WebDAV(Work) : BACKGROUND ENUM INFO : QUEUE CLEARD
2023-06-26 11:20:03.376 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:20:14.535 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:20:30.525 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:20:53.576 [ERROR] RD : WebDAV/None(Work) : Get Sub Folder List Error : /@Recycle : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:401,“RaiException”:“WebDAV List : /@Recycle/ : Failed : “,“Filename”:”/@Recycle/”,“WebExceptionStatus”:“ConnectionClosed”,“InnerException”:“Connection closed.”}
2023-06-26 11:20:55.440 [ERROR] RD : WebDAV/None(mir_upload) : #### FOLDER ENUM : API Call Error : {“WinErrorCode”:5,“NotifyErrorCode”:104,“RaiException”:“WebDAV List : / : Failed : “,“Filename”:”/”,“WebExceptionStatus”:“ProtocolError”,“InnerException”:“401 Unauthorized”,“WebResponseCode”:401,“HttpException”:“Unauthorized : \n\n401 Unauthorized\n\n
Unauthorized
\n\n”}2023-06-26 11:23:04.456 [ERROR] RD : WebDAV/None(mir_upload) : #### FOLDER ENUM : API Call Error : {“WinErrorCode”:5,“NotifyErrorCode”:104,“RaiException”:“WebDAV List : / : Failed : “,“Filename”:”/”,“WebExceptionStatus”:“ProtocolError”,“InnerException”:“401 Unauthorized”,“WebResponseCode”:401,“HttpException”:“Unauthorized : \n\n401 Unauthorized\n\n
Unauthorized
\n\n”}2023-06-26 11:25:19.293 [ERROR] RD : WebDAV/None(mir_upload) : #### FOLDER ENUM : API Call Error : {“WinErrorCode”:5,“NotifyErrorCode”:104,“RaiException”:“WebDAV List : / : Failed : “,“Filename”:”/”,“WebExceptionStatus”:“ProtocolError”,“InnerException”:“401 Unauthorized”,“WebResponseCode”:401,“HttpException”:“Unauthorized : \n\n401 Unauthorized\n\n
Unauthorized
\n\n”}
